connorsapps
Oct 23, 2022Tutor
LAN Invalid MAC address.
When going to add a static ip under Advanced > Setup > LAN Setup. Going to add an address reservation don't work for any of my devices. When clicking add I get the message: Invalid MAC address. 8...
- Oct 23, 2022
This is a known issue and has been passed on to NG.
Find downloads here;
https://www.netgear.com/support/product/R8000P.aspx#download
Oct 23, 2022Guru - Experienced User
- SimonB1979Oct 23, 2022Star
you could downgrade the FW, add your reservations, then upgrade again and the settings will stay tho it’s a hassle! 😇
that’s what I’ve been doing with the latest FW and the NTP // Invalid Mac problems! 🙂
the 6to4 was solved with using DHCP server option! 😀
- connorsappsOct 23, 2022TutorThanks so much for the quick help. I was getting close to throwing my router and it’s 90s interface into a pond.
- obnaesNov 12, 2022Initiate
I would use the word "solution" carefully. LOL It did not work for me., I am at the latest firmware and this feature worked then but the upgrade, not only broke the feature, but deleted all of my existing address reservations #doublefail
- FURRYe38Nov 13, 2022Guru - Experienced User
I recommend using last working version of FW.
This is a known issue and NG IS working on a solution.
