connorsapps
Oct 23, 2022Tutor
LAN Invalid MAC address.
 When going to add a static ip under Advanced > Setup > LAN Setup. Going to add an address reservation don't work for any of my devices. When clicking add I get the message:     Invalid MAC address. 8...
- Oct 23, 2022
This is a known issue and has been passed on to NG.
Find downloads here;
https://www.netgear.com/support/product/R8000P.aspx#download
Oct 23, 2022Guru - Experienced User
SimonB1979
Oct 23, 2022Star
you could downgrade the FW, add your reservations, then upgrade again and the settings will stay tho itâs a hassle! đ
thatâs what Iâve been doing with the latest FW and the NTP // Invalid Mac problems! đ
the 6to4 was solved with using DHCP server option! đ
