crabbiest's avatar
crabbiest
LAN Port LED is blinking R7800
First post and new Netgear user.
New R7800 appears to be working flawlessly. I have 2 devices connected to LAN ports 1 and 3. The first port is a desktop and the third port is a printer. I was able to read that the LEDs on the R7800 will light up White for gigabyte (my port 1) and Amber for port 3 since my old printer doesn't have gigbyte capability.
I am curious though why both these ports seem to blink continuosly. I am pretty sure the desktop is accessing the internet doing updates, etc. while I am not actively surfing. However, I don't understand why port 3 (the one the printer is connected to) blinks continuosly when there isn't any print activity.
Hope someone will clue my in. I have been looking over manuls and googling the LAN ports blinking but most of the discussion on line is about the power and WAN LEDs blinking.
  • A tiny amount of traffic goes on even when a device is idle and does nothing. This is keep-alive and also DHCP/DNS polling
    • myersw's avatar
      myersw
      Master
      Normal network chatter. Nothing to worry about. With the number of devices I have on line, the lights flash almost constantly.
    • crabbiest's avatar
      crabbiest
      Thanks to microchip8 and meyersw! I thought it was likey nornmal. The blink rate for the LAN port LEDs on my old Linksys wrt1900ac were different (and slower) for the port the printer was connected.
      So far this new netgear router rocks. 5+ stars out of 5 for the wireless range.
      • myersw's avatar
        myersw
        Master
        Glad it is working well for you. IMHO the r7800 is the best go to Netgear router right now. May not have all the shinny goo gaus of the newer, but the r7800 seems to work for most folks where the newer don't.
