kennyshewchuk
Feb 21, 2017Aspirant
LAN Speed Issue with R6700
Good Evening, I have a media server that accesses the internet through my router on the first LAN port. Initially, I was pulling about 900mbps on my gigabit internet connection. All of a sudden I...
- Feb 21, 2017
So the direct connection ran at ~900, and the router wired path also ran about ~900, but suddenly dropped to ~400. Retesting the direct connection still showed ~900. Is that all correct?
Rebooting the router and the media server is the obvious first step - if you haven't done that, you should start there. Disconnect any other devices from the router, just in case they are active (windows update or some similar drag you might not realize is going on).
If you have done that, maybe try resetting the router, and test it with the factory default settings.
Feb 21, 2017Guru - Experienced User
WMM should be enabled, but that only applies to WiFi, not wired connections.
Did you try connecting the media server directly to the internet port (bypassing the router), and measure the speed that way?
kennyshewchuk
I did connect it directly and received about 900mbps. It only seems to slow down when I am going through the router.
- StephenBFeb 21, 2017Guru - Experienced User
- kennyshewchukFeb 26, 2017Aspirant
It appears my router had some configuration issues beyond just this particular issue. My ISP determined I needed to take the router to factory defaults to resolve another issue.
Thank you for the suggestion, I am now running closer to 700mbps which is at least better than where I was at.
