buckeyestargaze
Oct 31, 2015Star
Lan speed limited to 100mbps? R7500
I have a nighthawk R7500 AC2300 gigabit router and while troubleshooting something else I noticed that in the router Genie setup all four of the lan ports in use are showing 100mbps speed. All of th...
- Oct 31, 2015The router ports are auto-sensing. The NIC drivers will often have a speed setting, so check there. Double check your Ethernet cables. They should be Cat5E or better. As a last resort, perform a factory reset of the router.
TheEther
Oct 31, 2015Guru
buckeyestargaze
Nov 02, 2015Star
It turns out the problem was the ethernet cable. I had a cat5e cable on the computer, but replacing the cable with a new one brought the speed to 1gbps.
