buckeyestargaze
Oct 31, 2015Star
Lan speed limited to 100mbps? R7500
I have a nighthawk R7500 AC2300 gigabit router and while troubleshooting something else I noticed that in the router Genie setup all four of the lan ports in use are showing 100mbps speed. All of th...
- Oct 31, 2015The router ports are auto-sensing. The NIC drivers will often have a speed setting, so check there. Double check your Ethernet cables. They should be Cat5E or better. As a last resort, perform a factory reset of the router.
TheEther
Oct 31, 2015Guru
- buckeyestargazeOct 31, 2015Star
Thanks for the reply. I have tried to change the NIC "Speed and Duplex" setting from the default "Auto Negotiation" to "1.0Gbps Full Duplex". Neither setting has any effect on the speed. The cable is 50' Cat5e. I'm very reluctant to do a factory reset on the router but I suppose it can be done if I have to.
- buckeyestargazeNov 02, 2015Star
It turns out the problem was the ethernet cable. I had a cat5e cable on the computer, but replacing the cable with a new one brought the speed to 1gbps.
