meldgr8t's avatar
meldgr8t
LAN to WAN Configuration
Hi, My situation is: 1. Vodafone HG659 modem/router (IP 192.168.1.1) that connects me to internet. 2. Netgear R8000 (located upstairs): IP 10.0.0.1.  All LAN ports on the back of it are connected ...
  • TheEther's avatar
    TheEther
    Dec 07, 2015
    meldgr8t
    1. Your home network will still be protected by the Vodafone router providing your 192.168.1.X subnet.
    2. JamesGL has given you the instructions for enabling AP Mode.  Once you enable it, you will have to force all devices with 10.0.0.X addresses to obtain new IP addresses in the 192.168.1.X subnet.  You can do this by either rebooting them or forcing them to renew their DHCP lease.
