bfwaring
Jul 02, 2021Aspirant
Landline connection to AX6 CAX30
Hello, Possible to connect my land line to the Nighthawk CAX30? I don't see a voice port on the back of the modem. We have Xfinity Help!
Jul 02, 2021Guru - Experienced User
What actual model do you have? AX2700 is a speed.
If you're referring to the CAX30, no, it does't have voice capability.
You could always get some type of voip service/device like Ooma.
- bfwaringJul 02, 2021AspirantYes sir, sorry I meant CAX30
Thanks for your response. Do you happen to know if Nighthawk has a modem/router that will support a landline? Thanks again 👍🏻- plemansJul 02, 2021Guru - Experienced User
They do but not currently AX routers or docsis 3.1 devices.
I think the current fastest is the C7100V
