bfwaring
Jul 02, 2021Aspirant
Landline connection to AX6 CAX30
Hello, Possible to connect my land line to the Nighthawk CAX30? I don't see a voice port on the back of the modem. We have Xfinity Help!
bfwaring
Yes sir, sorry I meant CAX30
Thanks for your response. Do you happen to know if Nighthawk has a modem/router that will support a landline? Thanks again 👍🏻
Jul 02, 2021Guru - Experienced User
They do but not currently AX routers or docsis 3.1 devices.
I think the current fastest is the C7100V
