digilos10
Jun 21, 2020Aspirant
Laptop connection breaks network
Hello everyone, I have an RS400 Nighthawk router that I'm able to connect to a variety of smart devices and a couple of Mac laptops in my home, however when I connect my Windows 10 machine to the rou...
- Jun 22, 2020
You've got a couple options.
1. Put the xfinity combo device in modem only/passthrough mode. it disables its routing functions and just leaves the netgear in control. it disables the wireless on the xfinity device.
2. put the netgear in access point mode. It disables routing on the netgear and just leaves it as an access point. Wireless and wired can still be used.
3. place the netgear in the xfinity's dmz.
Jun 21, 2020Guru - Experienced User
do you have the RS400 setup in access point mode or the "wireless modem" setup in modem only/passthrough mode? Probably not if the wifi is on. That would put you in a double nat if both are running in router mode.
https://kb.netgear.com/30186/What-is-Double-NAT
What firmware is on it?
What modem are you using?
- digilos10Jun 21, 2020Aspirant
Hello, thanks for the prompt reply.
I am using Firmware V1.5.0.34 and the RS400 router which is the Nighthawk AC2300
It looks like I have a Double NAT setup though becasue I have a Comcast router which has a Wi-Fi router, and my Netgear connects to that so I have a second network.
- plemansJun 22, 2020Guru - Experienced User
- digilos10Jun 23, 2020Aspirant
Thanks for that information. Will work on implementing those steps.
