Kaveh300
Aug 23, 2015Aspirant
Laptop doesn't see external HDD on R8000
I have an external Hard Drive Connected to my R8000 for the shared drive capability. I have my Desktop and my Laptop that use the drive, I upgraded both to Windows 10. Now my Laptop doesn't see the H...
- Aug 28, 2015
This is isolated as OS problem. Please try the following.
1. Disable antivirus and firewall. If it will not work proceed to 2.
2. Check if "Client for Microsoft Network" is enabled. If it is not then check no. 3.
3. Check for the "MICROSOFT 6to4 ADAPTER"
- Go to Control Panel
- Device manager
- Highlight Network Adapters
- Click View
- In the expanded view you will see a long list of numbered "MICROSOFT 6to4 ADAPTER". Right click and select "DELETE" until only one item remains.
JamesGL
Community Team
JamesGL
Aug 27, 2015NETGEAR Employee Retired
Hi Kaveh300,
Welcome to Community!
Please try to access the readyshare via the windows explorer. Open a folder or windows explorer then type on the address bar \\readyshare or the IP address of the router e.g. \\192.168.1.1 and check if you can access it. If yes, you may need to mount the drive again using the windows explorer so that it will appear again in your laptop.
JamesGL
Community Team
