mr_grieves
Mar 16, 2016Tutor
Laptop keeps losing internet connection - R7000
I've had an R7000 on my home network for a few months and the following problem is occuring with increasing frequency. I have a laptop running Windows 7 (connects at 2.4GHz) that I use throughout...
- Mar 17, 2016
There are numerous known bugs (many doing with 2.4GHz devices) in that release of firmware which Netgear is aware of and that is why Netgear pulled that firmware release.
You will want to roll back your firmware to v.1.0.4.30. You can download it from the R7000 Downloads Support Page. After rolling back the firmware, you will want to do a factory erase of your router settings, then reconfigure everything as you like it/want it. DO NOT use a backup configuration file to restore your settings.
mediatrek
Mar 16, 2016Virtuoso
What version firmware do you have on your R7000?
- mr_grievesMar 17, 2016Tutor
Running firmware V1.0.6.28_1.1.83
- mediatrekMar 17, 2016Virtuoso
You will want to roll back your firmware to v.1.0.4.30. You can download it from the R7000 Downloads Support Page. After rolling back the firmware, you will want to do a factory erase of your router settings, then reconfigure everything as you like it/want it. DO NOT use a backup configuration file to restore your settings.- mr_grievesMar 17, 2016Tutor
Thanks, I didn't realize the firmware had been recalled. I believe I updated when I first setup the router. I have reverted back so I will see what happens.
