vacho
Jul 14, 2021Aspirant
laptop stolen - how to reset the VPN keys
Hello Community, My laptop got stolen and I want to make sure they cannot access my VPN. How do I reset the VPN keys to ensure security? I have the nighthawk 1900 Thank you everyone ...
DarrenM
Jul 15, 2021Sr. NETGEAR Moderator
This theard may help you out.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Change-OPENVPN-key/td-p/1630173
DarrenM
- antinodeJul 15, 2021Guru
Not a model number. Look for "Model" on the product label.
> This theard may help you out.Thanks for the indirect pointer to the very long thread. My quick
look at it suggested that enabling Telnet access to the router would be
needed to do the actual work.How, exactly, would you suggest that a victim do that, considering
that Netgear seems to have broken the usual scheme in every R7000
firmware version after V1.0.9.42_10.2.44"?https://community.netgear.com/t5/x/x/m-p/1786837
Or am I missing something? - vachoJul 15, 2021Aspirant
that really did not seem straightforward and easy.
Netgear does not have proper documentation on how to do this? The link has a bunch of comments and suggestions, I dont know who and what to follow.
Is there a way to only allow certain IP's to connect to my VPN?- antinodeJul 15, 2021Guru
> that really did not seem straightforward and easy. [...]
That certainly was my impression. Also, I just skimmed over that
procedure, but I got the impression that some of it was not the way
I'd've done things.But if Telnet (shell) access to the router is a requirement, and
Netgear has removed that capability from every firmware version starting
with "V1.0.9.60_10.2.60" (2018-11-28), then it's not clear that
improving that procedure or its documentation would be helpful.Whether that four-year-old procedure, if it could be used at all,
would still apply to more recent firmware versions is another mystery.> Not a model number. Look for "Model" on the product label.
Still wondering.
