vacho
Jul 14, 2021Aspirant
laptop stolen - how to reset the VPN keys
Hello Community, My laptop got stolen and I want to make sure they cannot access my VPN. How do I reset the VPN keys to ensure security? I have the nighthawk 1900 Thank you everyone ...
DarrenM
Jul 15, 2021Sr. NETGEAR Moderator
This theard may help you out.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Change-OPENVPN-key/td-p/1630173
DarrenM
antinode
Jul 15, 2021Guru
Not a model number. Look for "Model" on the product label.
Thanks for the indirect pointer to the very long thread. My quick
look at it suggested that enabling Telnet access to the router would be
needed to do the actual work.
How, exactly, would you suggest that a victim do that, considering
that Netgear seems to have broken the usual scheme in every R7000
firmware version after V1.0.9.42_10.2.44"?
https://community.netgear.com/t5/x/x/m-p/1786837
Or am I missing something?
