HSP
Dec 06, 2017Aspirant
Large difference between WiFi speed and direct link speed
 I have a tested speed of 350 mbps when I connect directly to the modem.  That speed drops to less than 25 mbps over wifi on multiple devices.  What do I need to do to improve the wifi speed?
- Dec 14, 2017Is your WMM enabled? I had very slow internet speeds for awhile likely a result of firmware update in June but didn't really pay attention to it until recently. I spent last night troubleshooting it (including downgrading firmwares). I finally saved my config, reset the router and I was getting full speed. I loaded my config again and back to 20 Mbps. I reset the modem and started from scratch fiddling with different settings. I finally determined it was the WMM. The moment I enabled it went back to full speed. With one of the firmware updates it seems that WMM is required to attain full speed over wireless.
HSP
Dec 14, 2017Aspirant
I am experiencing a large difference in the tested speed provided by my router. I run the tests on my MacBook Pro.
When connected by ethernet I am testing at 350 Mbps
When I run the same test over WiFi my speed drops to a range of 15 - 27 Mbps
I am using the 5G setting and have the Firmware Version 1.0.9.14 installed.
Phaelen
Dec 14, 2017Initiate
- HSPDec 14, 2017AspirantTHANK YOU!! That did the trick!!
