heikeg
Apr 16, 2016Aspirant
Last few days i have strict nat type on ps3 ghost
for the last few days i keep having strict nat type on my ps3 when im playing call of duty ghost, i never had that before, i did reset router already 3 times to default but still getting strict nat t...
- Apr 17, 2016
You may have to check with your ISP about setting up IPv6. You could always try Auto Detect and see if the router can figure it out by itself.
TheEther
Apr 17, 2016Guru
Your settings are not displaying properly.
Make sure there is only one router in your network. If your ISP box is also a router, then put it into bridge mode or convert your R8000 into an Access Point.
Then perform the following steps on whatever device is acting as the router.
- If available, set NAT filtering to Open. On Netgear, this is in WAN Setup. An ISP box may not necessarily have this setting or it may be called something different.
- Enable UPnP
- Reserve an IP address for your console. On Netgear, this is in LAN Setup. If the ISP box can't do this, then configure a static IP address on your console. Make sure it's outside of the range of IP addresses managed by your DHCP server. Otherwise, you run the risk of duplicate IP addresses. Change the range, if necessary to free up an IP address.
Reboot the console.
heikeg
Apr 17, 2016Aspirant
i only have one router,
nat filtering is open,
UPnP is enabled.
How do i reserve an IP address
here are the settings in LAN Setup
Device name R800
IP Address 192.168.1.1
IP Subnet Mask 255.255.255.0
RIP Direction Both
RIP Version Disabled
Use Router as DHCP Server is checked
Starting IP Address 192.168.1.2
Ending IP Address 192.168.1.254
- heikegApr 17, 2016Aspirant
ok i found out how to reserve an IP address when i turn the ps3 on it tells me the ip address is 192.169.1.3 so i add that ip to address reservation but my ps3 is still strict nat type . yes i did reboot the router anything else i can do ? i try to connect wiresless and over cable to my router both giving me strict nat type. could it have something to do wth my internet provider?
- TheEtherApr 17, 2016Guru
Your Internet provider could have something to do with it. Is the IP address on the R8000 Internet port in any of these address ranges?
- 10.0.0.0 - 10.255.255.255
- 172.16.0.0 - 172.31.255.255
- 192.168.0.0 - 192.168.255.255
how can i check if the IP address is on the R8000 Internet port
