heikeg
Apr 16, 2016Aspirant
Last few days i have strict nat type on ps3 ghost
for the last few days i keep having strict nat type on my ps3 when im playing call of duty ghost, i never had that before, i did reset router already 3 times to default but still getting strict nat t...
- Apr 17, 2016
You may have to check with your ISP about setting up IPv6. You could always try Auto Detect and see if the router can figure it out by itself.
TheEther
Apr 17, 2016Guru
Your Internet provider could have something to do with it. Is the IP address on the R8000 Internet port in any of these address ranges?
- 10.0.0.0 - 10.255.255.255
- 172.16.0.0 - 172.31.255.255
- 192.168.0.0 - 192.168.255.255
heikeg
Apr 17, 2016Aspirant
how can i check if the IP address is on the R8000 Internet port
- TheEtherApr 17, 2016Guru
Log onto the R8000 and click on Internet.
- heikegApr 17, 2016Aspirant
this is what i see when i go to internet
Does your Internet connection require a login? NO
Get Dynamically from ISP is checked
Use Static IP Address is unchecked
IP Address 100.109.29.83
IP Subnet Mask 255.255.224.0
Gateway IP Address 100.109.0.1
Domain Name Server (DNS) Address
Get Automatically from ISP is checked
Use Default Address is checked
Ok, it's your ISP. IP address 100.109.29.83 is a private IP address. Your ISP may be using carrier grade NAT.
You have two options.
- Rent a public IPv4 address from your ISP.
- If your ISP supports IPv6, then enable it on your router.
