BillGeddes's avatar
BillGeddes
Latency issue after firmware update R7900P...Having same intermittent (frequent) DNS issue...
Tried to enable IPv6 using auto detect and came up with the following:
Does not seem to have resolved my frequent DNS issue...
I'm on a CM550 > R7900P (Firmware Version
V1.4.3.88_1.3.50)
If I go direct from modem to computer I'm fine, but using wireless I get the DNS trouble- any other advice?
1 Reply
  • plemans's avatar
    BillGeddes
    1. it doesn't look like your isp is supplying you a dns setting automatically. You can try using google/cloudfare's ipv6 DNS
    2. if that doesn't work, please start your own post instead of jumping on someone elses so we can individually help you and not get your info confused with the OP's.
