arealdave's avatar
Nov 16, 2021
Latency issue after firmware update R7900P
Hi, I did the rececent firmware update to V1.4.2.84_1.3.42 and ever since we've been having trouble finding and loading websites. We are on Spectrum cable modem but our neighbors are not having this issue so I don't think it's on Spectrums end. I also switched DNS from Spectrum to Google servers to see if that fixed anything and it didn't so I don't think it's a DNS issue.
I'm wondering if anyone else has had this issue and if there is a solution other than buying a new router? It worked great before the firmware update.
Thanks
  • plemans's avatar
    Nov 16, 2021
    IPv6 is found under advanced---->advanced setup---->ipv6
    that's under the browser based gui
  • plemans's avatar
    I've seen several issues across multiple product lines on the latest firmware versions.
    Some have been fixed by enabling ipv6
    Others have needed to downgrade a version. I'd try the IPv6 first and then the downgrade.
      • plemans's avatar
