TechByter
May 30, 2018Aspirant
Latest firmware breaks NAS setup
Previously I created this topic: https://community.netgear.com/t5/Using-your-ReadyNAS/Will-the-latest-security-firmware-update-create-a-problem-with/td-p/1578063
Nobody responded, so I tried i...
- Jun 14, 2018
Thanks, Blanca. That beta BIOS version was provided by support shortly after I bought the router because it wouldn't work with the Seagate 2TB hard drive and it was unclear where the fault was. Because of the VPNFilter threat, I have upgraded the router to a Netgear X10 and I found that it also does not work with the Seagate drive. Thus the fault was Seagate's. I've replaced the 2TB drive with a 4TB Western Digital drive and it performs properly, so the problem is solved.
TechByter
Jun 14, 2018Aspirant
Blanca_O
Jun 14, 2018NETGEAR Employee Retired
Hi TechByter,
Thank you for your feedback. Glad that it's working now.
Blanca
Community Team
