Retired_Member's avatar
Retired_Member
Dec 02, 2017
Latest firmware killed my Nighthawk AC1750 R6700v2
I have so many issue with this unreliable router. I have another post @ https://community.netgear.com/t5/WiFi-Range-Extenders-Repeaters/My-nightmare-has-begun-from-Nighthwak/m-p/1444481#M20761   I ...
  • Retired_Member's avatar
    Retired_Member
    Dec 13, 2017
    Update:
    The solution works I think.
    Since I already did static ip way before for port forwarding, the only setup was different was the DNS. I have both DNS set to the google DNS addresses, not the DNS addresses were defaulted. It's more than 40 hours and my internet is still good.
