Retired_Member
Dec 02, 2017Latest firmware killed my Nighthawk AC1750 R6700v2
I have so many issue with this unreliable router. I have another post @ https://community.netgear.com/t5/WiFi-Range-Extenders-Repeaters/My-nightmare-has-begun-from-Nighthwak/m-p/1444481#M20761 I ...
- Retired_MemberDec 13, 2017
Update:
The solution works I think.
Since I already did static ip way before for port forwarding, the only setup was different was the DNS. I have both DNS set to the google DNS addresses, not the DNS addresses were defaulted. It's more than 40 hours and my internet is still good.
Retired_Member
Dec 11, 2017Sorry I haven’t replied for a while since I have tried different ways to narrow down the issue. Finally I found out once I have my new Amcrest ip cam (ip2m-841B)installed, it has the issue.
It’s not like always eveynight lose internet. It’s actually like every 24 hours. I unplugged my cam and the internet was good for more than 24 hours. Yesterday morning, after 32 hours good internet connection, I reset and added the cam back. This morning, internet was gone again. Then I did a research, found out some people also had the issue and blamed it’s a bug from netgear. Here is the topic with a solution. I’m going to try it tonight.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/WiFi-Internet-Only-drops-about-every-12-hours-with-WiFi-cameras/td-p/1335519
My setup does have static ip but does not have static dns. Hopefully the solution can fix this issue.
Retired_Member
Dec 13, 2017Update:
