wbaich
Jan 05, 2021Initiate
Latest firmware update for ex2700
Hello, I received an email from Netgear saying a new firmware update is avaible, but when I log in, and click on update firmware, it just searches for ages and doesn't show me any update. The de...
- Jan 05, 2021
What version are you on?
you can find the latest firmware as well as a manual for manually installing it on here:
Jan 05, 2021Guru - Experienced User
- wbaichJan 05, 2021Initiate
Thanks, I downloaded the latest version and uploaded it myself. Thought it would fix the issue of my extender dropping out every so often but nevermind. Thanks again
- plemansJan 05, 2021Guru - Experienced User
how far from the router is the extender?
Have you tried changing the channel the router is broadcasting on for 2.4ghz?
2.4ghz is more sensitive to interference and so sometimes you have to change channels.
