daust126
Mar 27, 2021Follower
latest firmware version number please
Hi, I want to be sure Netgear Genie and Nighthawk app are correct when they say there are no firmware updates available for the R6400 router I have. I'm wondering because I got an email saying an upd...
- Mar 27, 2021
> [...] when I use the firmware assistant to check for updates it says
> none available. [...]Trust no one, I always say.
> [...] Right now I have firmware version V1.0.1.62_1.0.41". [...]
Only a couple of steps behind.To see one opinion of what's current/available:
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:
antinode
Mar 27, 2021Guru
