spopiela
Jul 06, 2019Guide
Latest R7000 firmware update breaks router . Unable to do a reset
Did latest update this morning. Router did not complete update. I can’t do a reset . Appears to be bricked. Is there a way to get back to initial factory firmware?
microchip8
Jul 06, 2019Master
spopiela
Jul 06, 2019Guide
I'll give it a try. Thanks
Further info. I used the Nighthawk app which indicated that an update was available. After a very long time, I checked the router light and there was no activity. Just a amber poer light with a few other light dimly lit. I'm very careful doing updates and have a UPS supply on the home network. Using the IOS Nighthawk App may not be the best approach to updating, since it is using the network at the time of update,
- microchip8Jul 06, 2019Master
don't use any apps/wifi to do firmware updates. use the Web UI using a wired computer http://192.168.1.1
- michaelkenwardJul 07, 2019Guru - Experienced User
