spopiela
Jul 06, 2019Guide
Latest R7000 firmware update breaks router . Unable to do a reset
Did latest update this morning. Router did not complete update. I can’t do a reset . Appears to be bricked. Is there a way to get back to initial factory firmware?
spopiela
Jul 06, 2019Guide
I'll give it a try. Thanks
Further info. I used the Nighthawk app which indicated that an update was available. After a very long time, I checked the router light and there was no activity. Just a amber poer light with a few other light dimly lit. I'm very careful doing updates and have a UPS supply on the home network. Using the IOS Nighthawk App may not be the best approach to updating, since it is using the network at the time of update,
microchip8
Jul 06, 2019Master
don't use any apps/wifi to do firmware updates. use the Web UI using a wired computer http://192.168.1.1
- michaelkenwardJul 07, 2019Guru - Experienced User
