SmallTrader
Oct 10, 2021Apprentice
Latest R8000 firmware R8000-V1.0.4.76_10.1.82 - Random "Site Not Found" issues
Hi There, I received a notification of a new firmware (R8000-V1.0.4.76_10.1.82) for R8000 recently. I am currently running R8000-V1.0.4.66_10.1.75 which is very stable. I know the chequered hi...
Nov 10, 2021Guru - Experienced User
"Thanks for posting. There's been multiple products impacted by this latest round of updates that cause dns issues. Easiest fastest way to fix is the downgrade option. We're just hoping one of the engineers sees the posts since its rare to find someone on here."
no_one_here wrote:
I too am experiencing the same issue after upgrading the firmware.
Anonymous
Nov 11, 2021It seems that Netgear have abandoned its customer base and left us to fix things ourselves after their screw up.
A rough and ready workaround for the dns issue is as follows:
Go to into routeradmin pages go to advanced home and note the dns entries.
Go to windows control panel and click on ‘Network and sharing centre’
Click ‘change adaptor settings’. DoubleClick the appropriate ethernet/wifi adaptor and click properties,
highlight Internet protocol version 4(TCP/IPv4) click properties:
Click ‘use the following DNS server address’ and enter dns numbers in the ‘preferred dns server’ and alternative server boxes.
This should stop the page not found error
- chasentJan 17, 2022Aspirant
Following your recommendation. What IP address, Subnet mask etc should I be entering to resolve this issue. Thanks
- AnonymousJan 17, 2022
Hi
All you need to do is log on to the router's admin pages and get the dns numbers from the advanced home page and enter them in the network adaptor properties. When you have the ip numbers just follow the procedure I described in the previous message to enter them. They are the only settings you need to change.
