R7_0_0_0_User
Jan 23, 2017Tutor
Latest Security Vulnerability KB Article links to old R7000 Firmware
Hi, The KB Article for the latest security vulnerability links to the firmware version 1.0.5.70 firmware for R7000: http://kb.netgear.com/30632/Web-GUI-Password-Recovery-and-Exposure-Security-V...
- Jan 25, 2017
The link in the article has been updated to the latest firmware available for R7000.
Thank you guys for bringing this to our attention.
Jan 25, 2017Guru - Experienced User
R7_0_0_0_User wrote:
Hi StephenB
Thanks for the infos. I found the link here: http://www.cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5521 this is why I called it the "latest security issue". Are you saying that
CVE-2017-5521 is not a current or new security issue? German Tech-Press (heise.de) posted last week that netgear devices have a new "big" hole and also pointed to these links.
I agree that the CVE is current, and points to that KB article ( https://web.nvd.nist.gov/view/vuln/detail?vulnId=CVE-2017-5521 ). And the CVE says the issue was vendor-reported.
I don't work for Netgear, so I don't have any inside info here. What I do know is that particular security issue was posted in May 2016.
So this is quite confusing. Hopefully Netgear can clarify it.
thelemonkid
Jan 25, 2017Luminary
But that link points to old firmware....? Or....?
I am now using R7000-V1.0.7.6_1.1.99.chk
It was suppossed to take care of a recent vulnerability. But is this another older one we talk about?
I read: Firmware fixes are currently available for the following affected devices. To download the firmware release that fixes the password recovery vulnerability, click the link for your model and visit the firmware release page for instructions:
- StephenBJan 25, 2017Guru - Experienced User
I believe it is older, and likely not an issue with R7000-V1.0.7.6_1.1.99.chk. But I think Netgear needs to comment.
- ElaineMJan 25, 2017NETGEAR Employee Retired
I have forwarded this to our engineering team and waiting for their response.
Will provide an update as soon as I have one.
