M3TALHEAD's avatar
Jun 13, 2020
Latest Update Bricked My R8000 Router
The latest firmware update (R8000-V1.0.4.52_10.1.67) bricked my router! I am using the  R8000 Nighthawk X6 AC3200 Smart WiFi Router. I utilized the web interface to update the firmware via a wired ...
  • michaelkenward's avatar
    Jun 14, 2020
    There is more severe, recovery reset, that you could try:
    • Press reset for 30 seconds
    • Keep pressing reset while removing power
    • Keep pressing reset for another 30 seconds while apply power
    If it works, you may be able to use the usual method to flash the firmware again.
    Download the latest firmware for your device – or an older version if that is what you want – and read the Release Notes for how to install it.
    If that fails, you are into TFTP country.
    How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
    This also explains how to tell Windows to use TFTP on your PC.
    This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
    The good news is that TFTP has rescued many a dead device.
