M3TALHEAD
Jun 13, 2020Tutor
Latest Update Bricked My R8000 Router
The latest firmware update (R8000-V1.0.4.52_10.1.67) bricked my router! I am using the R8000 Nighthawk X6 AC3200 Smart WiFi Router. I utilized the web interface to update the firmware via a wired ...
- Jun 14, 2020
There is more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, you may be able to use the usual method to flash the firmware again.
Download the latest firmware for your device – or an older version if that is what you want – and read the Release Notes for how to install it.
If that fails, you are into TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR SupportThis also explains how to tell Windows to use TFTP on your PC.
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
The good news is that TFTP has rescued many a dead device.
michaelkenward
Jun 14, 2020Guru - Experienced User
DHayes1
Jul 30, 2020Aspirant
tried everything suggested nothing works. yes i have my IP set correctly on my ethernet card. Yes I used TFTP interface. Yes I rebooted router and did not click Put until orange light came on..... BTW the directions on the netgare solution page have an error. they say to set ethernet card IP to one ip then show a different IP in the loop window for TFTP.
