jangodog
Aug 01, 2017Aspirant
LED blinking AMBER
Hi one of the channel leds blinking amber, channel 1? Any idea why? Wifi and internet working fine:)
- Aug 04, 2017
Hi.Update, i figured it out why one of my ports turned amber when pc was turned of. Advice from a Danish forum told me to go to device manager/adapter card/power management and untick box " allow this computer to turn off unit to save power" Don't know if this is the right term in English but you know what it means:) Now the light is pure white turned off and on:)
michaelkenward
Aug 01, 2017Guru - Experienced User
The manual explains what the LEDs show:
>>> R7800 | Product | Support | NETGEAR <<<
Which LED are you talking about? A blinking LED usually means some sort of activity.
- jangodogAug 01, 2017Aspirant
Well it's channel 1 who did but now after turning on my desktop pc it turned white again? My X4S is connected to this one: http://www.netgear.com/support/product/CG3000-1STAUS.aspx And the CG 3000 is set to NAT so i use my X4S in bridgemode. i can see in wifi connection section that i run 1000mb on lan. I don't think the CG 3000 has AC speed but does that matter when i use the X4S who has all the bells and whistle?
- michaelkenwardAug 01, 2017Guru - Experienced User
jangodog wrote:Well it's channel 1
There are no LEDs for "channels".
If you mean the LED with 1 under it that is one of the Ethernet LAN ports.
See page 11 of the manual that I referred you to.
Lan port 1, sorry. But the amber only turns white when my pc is turned on and go back to amber when turned of ? Do i have to move the ethernet cable to another port?
