jangodog
Aug 01, 2017Aspirant
LED blinking AMBER
Hi one of the channel leds blinking amber, channel 1? Any idea why? Wifi and internet working fine:)
- Aug 04, 2017
Hi.Update, i figured it out why one of my ports turned amber when pc was turned of. Advice from a Danish forum told me to go to device manager/adapter card/power management and untick box " allow this computer to turn off unit to save power" Don't know if this is the right term in English but you know what it means:) Now the light is pure white turned off and on:)
jangodog
Well guess everything is okay then:) Thank's for your help.
jangodog
Aug 04, 2017Aspirant
- michaelkenwardAug 04, 2017Guru - Experienced User
Well done Sherlock.
Is that something you did in Windows?
- jangodogAug 04, 2017AspirantYep:)
- michaelkenwardAug 05, 2017Guru - Experienced User
One of those settings buried in the depths. In reality it probably doesn't achieve much beyond leaving the light on and perhaps using up a tiny amount of power. The fact that the light showed orange before means that you probably could have used the port to "wake up on LAN".
- jangodogAug 05, 2017Aspirant
Sure, but now it's just the color i prefer:) Thank's anyway.
