JeffreyY
Jan 25, 2021Guide
LED Lights Behavior on Ethernet ports changed
I have a desktop computer connection to one of the ethernet ports on my Nighthawk R6900P router. Up until about a month or so ago when connected and online the port LED would be white & blinking, a...
- Jan 25, 2021
Solid amber means the network chip is active at low Mbps. This is most likely for Wake-On-LAN purposes. If you have disabled WoL since then, then the chip will turn itself completely off hence why no LED is shining
microchip8
Jan 25, 2021Master
JeffreyY
Jan 25, 2021Guide
That's it!! Thank you!
