JmJacob
Jun 27, 2016Tutor
LED lights not working
I just set up my new Netgear R7800 as an access point, and it works completely fine, however, the all of the LED lights are off appart from the power LED. I know there is an option to turn them off/...
- Jun 27, 2016
That must be wish, in my experience with many different router from different vendor during review and testing time, I don't recall
such feature. I guess f/w can do such thing but personally that is low priority item among many issues to deal with. In my case if
I wanted something like that I'd attach some jury rigged circuit to the router to control the lights any way I want. You can make a
fearue request to NG, I guess.
JmJacob
Jun 27, 2016Tutor
Well I based my question off of reading the supplied manual in the box. I didnt know there was a full manual online. In there I found that there is an LED switch on the back of the router on top of software controlled effects. They both control the LEDs.
Thanks! Jacob
