Amiga_Dragon
Nov 19, 2019Tutor
LED lights not working/blinking
Hi, The LED lights of my Nighthawk are not working properly. Lan 1 and the USB LED's are off while just USB devices and the modem are connected to this Nighthawk. When I choose "Turn off all LE...
- Dec 02, 2019The problem has been solved.I restarted the router and in the router configuration I switched the LEDs off and on again.
Now the LEDs suddenly work as they should.
Even if I switch off the LEDs in the configuration, the extra led next to the power led will not stay on.
Only the power LED stays on, as it should be.
I have done a firmware upgrade to V1.0.2.63 today.
LEDs from the USB and from the 5Ghz and 4.2Ghz Wifi do it again, without any problems.
Even if I put a fixed network cable in the Netgear router, the LEDs from Lan 1 to 4 flash again.
michaelkenward
Nov 20, 2019Guru - Experienced User
Amiga_Dragon wrote:
Hi,
Are you using the LED switch on the back?
Amiga_Dragon
Nov 20, 2019Tutor
Hi Michaelkenward,
Yes, I have also tried the switch for the LEDs.
