Amiga_Dragon's avatar
Nov 19, 2019
LED lights not working/blinking
Hi,   The LED lights of my Nighthawk are not working properly. Lan 1 and the USB LED's are off while just USB devices and the modem are connected to this Nighthawk. When I choose "Turn off all LE...
  • Amiga_Dragon's avatar
    Dec 02, 2019
    The problem has been solved.
    I restarted the router and in the router configuration I switched the LEDs off and on again.
    Now the LEDs suddenly work as they should.
    Even if I switch off the LEDs in the configuration, the extra led next to the power led will not stay on.
    Only the power LED stays on, as it should be.
    I have done a firmware upgrade to V1.0.2.63 today.
    LEDs from the USB and from the 5Ghz and 4.2Ghz Wifi do it again, without any problems.
    Even if I put a fixed network cable in the Netgear router, the LEDs from Lan 1 to 4 flash again.
