Murrellj91
Feb 20, 2019Aspirant
LED Power Blinking AC1750
The amber “power” LED slowly blinks. No other LED’s are on or blinking. Tried unplugging, waited 8 hours for updates, and pushed reset button. Problem persists. Any ideas what to try next?
- Feb 22, 2019It was not brand new. It was about 6 months old. It was still under hardware warranty.
antinode
Feb 20, 2019Guru
> The amber "power" LED slowly blinks. [...]
You seem to be a candidate for the TFTP recovery scheme. See, for
example:
Murrellj91
Feb 21, 2019Aspirant
Actually, my router is version3.
I’ve attempted the TFTP firmware fix, but I continually receive the message “connect request failed.”
One difference from instructions is the light sequence. When I follow these steps, the lights are different: “Watch the Power LED. It starts with an orange color, and then start flashing.” and “Count at least 10 flashing power LED and release the reset button.”
For me, the router will not return to flashing orange power LED if I am pressing the reset button. Instead, when I power the router on while holding the reset button it just cycles through a sequence in which all the lights go on and off. It is only when I release the reset button that the orange power LED blinking continues.
At this point I press enter for the TFTP fix and I get “connect request failed.”
- Murrellj91Feb 22, 2019AspirantRan a ping test. Came back negative. Hardware is faulty. Returning router to NETGEAR.
Thanks for the help.- michaelkenwardFeb 22, 2019Guru - Experienced User
If that is a brand new device that has never worked – it isn't clear how this came about from your first message – then back to the seller is a better option.
- myerswFeb 22, 2019Master
And even better option is something other then Netgear when you return the box.
