Murrellj91
Feb 20, 2019Aspirant
LED Power Blinking AC1750
The amber “power” LED slowly blinks. No other LED’s are on or blinking. Tried unplugging, waited 8 hours for updates, and pushed reset button. Problem persists. Any ideas what to try next?
- Feb 22, 2019It was not brand new. It was about 6 months old. It was still under hardware warranty.
michaelkenward
Feb 22, 2019Guru - Experienced User
If that is a brand new device that has never worked – it isn't clear how this came about from your first message – then back to the seller is a better option.
myersw
Feb 22, 2019Master
And even better option is something other then Netgear when you return the box.
