Murrellj91
Feb 20, 2019Aspirant
LED Power Blinking AC1750
The amber “power” LED slowly blinks. No other LED’s are on or blinking. Tried unplugging, waited 8 hours for updates, and pushed reset button. Problem persists. Any ideas what to try next?
- Feb 22, 2019It was not brand new. It was about 6 months old. It was still under hardware warranty.
michaelkenward
Feb 22, 2019Guru - Experienced User
If that is a brand new device that has never worked – it isn't clear how this came about from your first message – then back to the seller is a better option.
Murrellj91
Feb 22, 2019Aspirant
- myerswFeb 22, 2019Master
Murrellj91 wrote:
It was not brand new. It was about 6 months old. It was still under hardware warranty.So return and get another. You are into pain and suffering.
- Murrellj91Feb 22, 2019AspirantYes, I am returning it to NETGEAR and they are sending me a new one.
- r0218Feb 24, 2019Aspirant
My R6700 has the exact same issue since morning today, I used TFTP to install the new firmware and the file is copied successfully but then the amber light blinks indefinitely, (it's the only light thats on rest lights are OFF)
I have the hardware warranty, 6 months old router however customer support says since i'm able to ping the Gateway IP and the router responds, this is not a hardware issue and needs another 50$ for providing tech support to fix this issue? the brand new one in amazon today is 79$
