Murrellj91
Feb 21, 2019Aspirant
LED Power Blinking AC1750
The amber “power” LED slowly blinks. No other LED’s are on or blinking. Tried unplugging, waited 8 hours for updates, and pushed reset button. Problem persists. Any ideas what to try next?
- Feb 22, 2019It was not brand new. It was about 6 months old. It was still under hardware warranty.
Murrellj91
Feb 22, 2019Aspirant
myersw
Feb 22, 2019Master
So return and get another. You are into pain and suffering.
- Murrellj91Feb 22, 2019AspirantYes, I am returning it to NETGEAR and they are sending me a new one.
- r0218Feb 25, 2019Aspirant
My R6700 has the exact same issue since morning today, I used TFTP to install the new firmware and the file is copied successfully but then the amber light blinks indefinitely, (it's the only light thats on rest lights are OFF)
I have the hardware warranty, 6 months old router however customer support says since i'm able to ping the Gateway IP and the router responds, this is not a hardware issue and needs another 50$ for providing tech support to fix this issue? the brand new one in amazon today is 79$
- antinodeFeb 25, 2019Guru
> [...] I used TFTP to install the new firmware [...]
Not a very detailed description of a moderately complex procedure,
with ample opportunities for error. As usual, showing actual actions
with their actual results (error messages, LED indicators, ...) can be
more helpful than vague descriptions or interpretations. The actual
"tftp" command, including the actual name of the firmware file, would be
a better start.> [...] customer support says since i'm able to ping the Gateway IP and
> the router responds, this is not a hardware issue [...]Assuming some missing details, that sounds plausible to me, but I
haven't looked closely at the actual warranty to see what's covered or
not.> [...] needs another 50$ for providing tech support to fix this issue?
> the brand new one in amazon today is 79$ [...]
I'd play with it a while, and then contribute it to a charity store
before I'd pay Netgear more for the privilege of further dealing with
Netgear. Of course, if your situation differs from the one of the
fellow who started this thread, then I'd also start a new thread for
this new situation.
