Hawkeye007
Jul 24, 2017Tutor
Lenovo Yoga 13 failing to connect to R8000 Nighthawk X6 AC 3200 router following firmware update
I have a Lenovo Yoga 13 running Windows 8.1 that has recently stopped connecting to my home wireless network following a firmware update that was applied to the router. The Netgear Router is now run...
- Jul 25, 2017
Ok, problem resolved.
I did a reset to factory settings and restored the configuration from a previous backup of the router.Not sure why this worked as the firmware is still at the latest update of V1.0.3.46_1.1.32 but all is well again in WiFi land.
Cheers!
Hawkeye007
William10a
Jul 24, 2017Master
Can you check the password that wireless is set for that ssid may have changed on the router or you may need to reset the router.
Hawkeye007
Jul 25, 2017Tutor
The passwords were changed as part of the troubleshooting in case they had become corrupted.
