Mac__Attack
Feb 26, 2021Aspirant
LG TV Connection issues with AC1600
We are having problems with our smart TV connecting to our wifi/modem router. My Macbook gets download speeds over 200mbps, but the TV doesn't pick up enough to stream Netflix or Prime. Never had a p...
Mac__Attack
Feb 27, 2021Aspirant
Thanks michaelkenward
The TV Model is LG 49UJ6200
The firmware version on the modem router is V1.02.02
I've connected the TV via it's network wifi settings, but it just doesn't seem to be getting the volume of data the other devices get. Some times, like right now it doesn't even pick up the wifi signal and my Macbook is getting over 200mbps from the network.
I never had this issue with a separate modem and router set up. Could that be the problem.
I will try running an ethernet cable direct to the TV and will see if that works.
michaelkenward
Feb 27, 2021Guru - Experienced User
Mac__Attack wrote:Some times, like right now it doesn't even pick up the wifi signal and my Macbook is getting over 200mbps from the network.
There's a chance that the Macbook is connected to the 5 GHz wifi. Most TVs, certainly older ones, use 2.4 GHz wifi. That's slower, but fast enough for a TV.
One thing to look for is wifi interference, which is more of a problem on 2.4 GHz.
You could see it using a different wifi channel helps. And check for any local wifi that may be getting in the way. From neighbours, for example.
Looks like that supports LAN Ethernet. Might be worth considering if wifi is a problem. Certainly easier to set up and less likely to fall over.
Shouldn't make much difference although experienced users prefer separate modems and routers. More choice of router features.
