roos5
Apr 10, 2021Guide
LG Tvs no internet via wifi
After activating bridge mode in my modem-router combo from my ISP, I’ve been experiencing connectivity issues with my 2 LG TVs (UM6970PAU and UJ6300), I can connect them via Wifi to my router but I’...
Apr 11, 2021Guru - Experienced User
did it work when the gateway wasn't in bridge mode?
Does it work if the extender is shut off?
roos5
Apr 11, 2021Guide
Good morning ,
1- Yes, I had one TV connected to the XR500. The second one was connected via the extender which at that time was in AP mode and was feeding via Ethernet from the ISP gateway,. Never got the second TV connected to the XR500.
2- Yes, tried that and didn’t worked.
- plemansApr 11, 2021Guru - Experienced User
It could be the bridge mode not functioning properly.
Have you tried taking the isp gateway out of bridge mode, disabling its wireless, and then just put the xr500's ip address into its DMZ?
- roos5Apr 11, 2021GuideThat was my previous setup and I was facing double NAT 24/7. In bridge mode everything is working better than ever with my gaming devices ( less lag, better ping, Upnp is finally working, etc) all other devices are getting internet access without any type of problem, the TVs are the ones with issues I don’t understand why.
Update: I realized that Netflix works on both TVs, but not anyother app or web browser. TV stills shows " No internet access via Wi-Fi". Tried ethernet with both TVs but no luck. Im not an expert here but these symptons are very familiar to device or ip conflict in a network.
