shaulch
May 02, 2020Tutor
Link speed is only 54Mbps for AC client (5GHz)
Hi, I'm using Netgear R7000, 5GHz AC1900 (Max 1300) using Macbook Pro 16' (but same issue seen also using Macbook pro 2016 & Ipad pro 10.5) There was no issue till today - I get only 54Mbps in...
- May 02, 2020
Fixed - this was the WMM . Somehow it must be enabled.
shaulch
May 02, 2020Tutor
