bgkymh
Feb 01, 2025Follower
Linking two routers together
Dear Netgear Community, I am currently using the R7800 as my router. I am considering upgrading to the RAX54S router. My question is after I install the new RAX54S could I relocate the R7800 to my b...
michaelkenward
Feb 02, 2025Guru - Experienced User
bgkymh wrote:
I am currently using the R7800 as my router. I am considering upgrading to the RAX54S router. My question is after I install the new RAX54S could I relocate the R7800 to my basement and connect it to the RAX54S via ethernet cable to act as an extender for better wifi coverage in my basement.
If the idea is to use the RAX54S as the main router, the best approach would be to put the R7800 in access ppoint (AP) mode.
That disables various features:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
But many useful things still work.The LAN ports are there for you to use, and ReadySHARE USB works for storage and printers.
You may or may not need to play around with wifi channels. Just play around. Many wifi clients will happily switch to the best network for them. Just don't expect a "Mesh" operation.
Also would the RAX50 router be a better choice than the RAX54S?
That's down to your preference. Try plugging your needs into the products page:
Wireless Routers for Home | NETGEAR
Just another user with time on their hands.
- plemansFeb 02, 2025Guru - Experienced User
Just an FYI, you can set it up like that. Both FURRYe38 and michaelkenward are correct. But it won't be "seamless" as AP mode (and those routers in general) aren't mesh devices. They don't offer the smart roaming features the orbi/MK nighthawk do. But you can still use the same ssid if you prefer, devices will just tend to be "sticky" and not roam as well as a true mesh system. One thing to ensure you do its make sure the AP is using a different wireless channel for both 2.4ghz and 5ghz as the primary to prevent wireless interference between the 2 devices.
