Beamster
Jun 12, 2021Aspirant
List of Unsupported Nighthawk AC Routers?
Is there a list of nighthak ac routers that are no longer supported? I am looking to upgrade but don't want to go backwards in greards to security updates.
microchip8
Jun 12, 2021Master
There is no such list.
- BeamsterJun 12, 2021Aspirant
I've seen something but lost track of it. Perhaps I'm using the wrong termonology. Maybe something like End of Service list.
microchip8 wrote:There is no such list.
- michaelkenwardJun 13, 2021Guru - Experienced User
microchip8 is correct, as usual. The term you are looking for is "End of Life", but the EOL tag turns up only when you start looking for a particular device. Even then it may not appear, because Netgear may still churn out firmware updates for things that you can't buy any more.
Not sure what such a list would do for you. If you can buy something, and if Netgear still has it on its product pages, it ain't EOL.
