markgrant's avatar
markgrant
Local wifi network won't appear
Plugged in new router (Netgear Nighthawk AC1750 / model R6700v2) and hooked up to existing Arris DG1670 cable modem. Local wifi network disappeared, not found. Plugged/unplugged, rebooted.   Usin...
  • markgrant's avatar
    markgrant
    May 25, 2018
    Manual automaticlly assumes I can connect to my network. I can't. Returning this. I always have problems with Netgear products. Will avoid completely from now on.
