JimJohnson
Feb 28, 2016Aspirant
Log files and Outlook 2010 Junk Folder
The R8000 router sends log emails identifying itself as ROOT@R8000 Outlook 2010 is trapping this email in its junk filter. It would be easy to simply add the email address to the safe senders list...
- Mar 06, 2016
I may have finally found the solution...
The From value is not just Root@R8000. It is Root@R8000 on behalf of [email protected] - the end piece being the address the user put in the router's email setup - - I am not sure if this is the authentication User Name or the Send To email address (in my case they are the same, which is why I don't know).
In Outlook 2010 I went into Junk Mail Options and put this fully qualified email address (that is, my own) into the Safe Senders list. Outlook 2010 has stopped moving the emailed router log into the Junk Mail folder.
JimJohnson
I already have a rule to move this email - in fact ALL my emails are moved out of the Inbox via rules and sent to other folders.
All used to be well, but following the last MS update to the junk mail filter, the router logs got identified as potential junk. No problem, just tell Outlook that the ROOT@R8000 sender is legit .... however Outlook 2010 will only add fully qualified email addresses or domains to its safe sender list. And therefore I can't override the newest junk mail filter.
Retired_Member
Feb 28, 2016Yes, you're correct, been playing with it and cannot make it work in 2013 either. I'll keep trying.
- JimJohnsonMar 06, 2016Aspirant
