Barrier
Dec 11, 2022Follower
Log In Proble
I'm unable to log in to my router using www.routerlogin.net Every attempt, even after re-setting password . . .admin/password...only times me out of the program; subsequent efforts have given simila...
Dec 11, 2022Guru - Experienced User
What model NG router do you have?
Try a factory reset and setup from scratch with a wired PC and web browser.
Be sure to clear out all web browser caches as well.
