Dave21444
Feb 11, 2022Aspirant
Log onto Nighthawk R7000 to configure as access point
I have Spectrum as my ISP and have their router set up. I have a Nighthawk R7000 and want to set it up as an access point that is hardwired to the Spectrum router. I have not been able to log on at...
Feb 11, 2022Guru - Experienced User
disconnect if from the spectrum router.
then reboot the netgear router and connect a pc/laptop to it.
on the pc/laptop open a command prompt and type ipconfig
The default gateway should be the routers address.
Use that to access it.
From there, put it in access point mode.
Then reconnect it to the spectrum modem
sorry spectrum router
